09-14-2020 07:47 PM (Last edited 09-14-2020 07:51 PM ) in
Galaxy SSolved! Go to Solution.
3 Solutions
09-14-2020 08:07 PM (Last edited 09-14-2020 08:07 PM ) in
Galaxy S2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do some more settings to save more battery, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
09-14-2020 08:07 PM in
Galaxy S3. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
4. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder.
6. If you use Facebook frequently then disable "auto play video"
And if you are mostly uses mobile on wifi connection then also disable "auto play videos" in YouTube.
09-14-2020 08:15 PM in
Galaxy S- Mark as New
A. Wifi scanning
A. Adaptive battery
09-14-2020 08:43 PM in
Galaxy Shttps://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
09-14-2020 08:48 PM in
Galaxy Syou can try several steps like use of dark wallpapers/themes
turn off auto sync
restrict background data usage
put unused apps to immediate sleep mode
optimize your device regularly
keep brightness in between 40-50%
turn off wifi/Bluetooth/location when not required
if you are using AOD, then use tap to show mode .
Yehi sab hai..try karo and let's c
09-23-2020 11:06 PM in
Galaxy SDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
