Highlighted
Beginner Level 3
My S10 battery draining fast after Android 10 update.
4 Comments
Highlighted
me too thats very desturping and annoying for a flagship level phone
Highlighted
i had the same problem , depleting your battery to zero will fix it
Highlighted
just using it upto 0% once will do it?
Highlighted
Hello there, Battery percentage may vary according to the usage (internet, call, video playback, etc..). However, if you feel that the device battery drains quickly when no function is used, please send the device to one of the service centres to discover and fix the problem. www.samsung.com/sa/support/servicelocation/.
