S10 battery drain issue
(Topic created on: 04-08-2019 01:23 PM)
Kimo87
I find the battery drain so quickly... I made a comparison test between my new S10 and my old Pixel... During my 7 hours sleep on flight mode the S10 lost 8% of the battery form 100 to 92  compared to my +2 years old Pixel under the same circumstances it lost 5% from 100 to 95... Knowing that the 5% in the Pixel is 139mah and the 8% in the S10 is 272mah which is almost the double!!
I am really disappointed with the battery performance of S10 noting that the Pixel is more than 2 years old 😑
Both are on Android pie and have the same set of downloaded apps.
5 Comments
RyoSan
i dunno about u , however am using s10+ gaming over the day the battery lasts for 8~10 hours while gaming most of the time its gr8 device
MasterFahad
Everything is amazing except the standby battery drain.
ajmal101
overall performance is outstanding except the battery draining while in standby.
Se7eN2
ive used my device from 8am till 4pm and still 73%. Maybe you can have it replaced since its still in warranty.
skhuhro
after yester update i am facing quick battery drain issue. any suggestions plz?
