01-29-2022 07:34 PM in
Galaxy SSolved! Go to Solution.
5 Solutions
01-29-2022 07:54 PM in
Galaxy SPlz click on three dots in the top corner and accept my comment as an answer
01-29-2022 08:14 PM in
Galaxy S[Hey snow, by the way if you see any value within my comment please accept it as an answer. Thanks.]
01-29-2022 09:33 PM (Last edited 01-29-2022 09:34 PM ) in
Galaxy SOr
Calibrate your S10 battery and see it helps
Check youtube for the guide
"Galaxy S10 Battery Calibration"
Hope it helps ❤
01-29-2022 11:42 PM in
Galaxy SYou could also try booting into recovery mode and doing a cache partition reset. It doesn't delete ur data, don't worry. If u need a guide let me know, or just google it.
Hope you figure it out soon
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting my answer as a solution.
Thanks 😊😊
01-30-2022 02:01 AM in
Galaxy S1.go to the power saving mood then you can see 3 things on it. On these settings
*limit CPU speed to 70%
*decrease brightness by 10%
*limit apps and home screen
2.use dark mood
3.use brightness level between 0%-30%
4.turn off Auto rotation
5.If you use mobite data change to the wifi
6.turn off bluetooth and some unused options.
7.if you have lot of unused apps, zip or sleep these apps
Galaxy SOr
Hope it helps ❤
Thanks 😊😊
2.use dark mood
01-30-2022 06:56 AM in
