Resolved! Solved
S10 Lite problem
(Topic created on: 12-30-2020 12:39 AM)
Hruthik
Hard reset is not working on my s10 lite
I tried holding vol up and power key and also volume down key and power key but it's just restarting
It's not showing the reboot screen
Anyone facing this problem?
It changed with Android 11, now you need to plug the USB-C / micro-USB cable along with the combination buttons (Press & Hold the Power and Volume Up button)
you can enter recover mode by doing this
connect ur device to pc by usbc cable
and make sure ur device is visible in computer as logged in
turn off ur device with the cable connected to pc
and now hold power up and switch on button together until the recovery menu pops up
3 Comments
Hruthik
it worked.
Thanks
Samsung_L5nrcvG
Beginner Level 4
oh finally!! Thanks a lot :)
