After the recent update my device is not detecting The charger and cable provided in the Box does I am not able to charge the phone using them in order to check if there is a problem with the port I tried the charger and cable of different phone and the phone started charging even if it's turned off it still charges with the other charging cable.
Now there's a twist you might be thinking that the charger and cable that came in the Box is bad well no because the other phone started charging with the Samsung cable and charger it means there is nothing wrong with it so to conclude the Samsung cable and charger can charge any other phone as of now but not the S10 light and Aston light gets charged with any other cable and charger but not with the Samsung charger and cable seems like a bug to me because if its hardware the phone would not charge at all I think this needs to be looked into let me know if you are facing this problem as well.
