chaitu197
Hi All, after updating May security patch update..
I have observed my device battery drains way faster than the usual.. Any suggestions on below or any one facing the same..
at Night 11PM - 47% (Location turned off)
at Morning 6AM - 22% it came.
Note : Till now I haven't faced this much 🙃
4 Comments
santosh234140
Beginner Level 5
In pune bsnl provide 150 mbps
Sahejpreet
Please check apps running on background. Those are consuming the battery. Move apps to deep sleeing which are not used frequently under battery and device care
Dr_Vivekvh
No battery after may month security update....getting more backup
cs-member13
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
