Restarting problem
(Topic created on: 07-21-2022 08:42 PM)
vichu_zz
Phone automatically restarting. 🙄
S20 FE 5G
The phone restarts when the phone is idle
11 Comments
b1ttu
**BEP** **beeeeeeep** **beeepbepbepbepbpbeep** 🤣 😂
1. Close apps running in the background
2.Update your phone
3.Check for Viruses
Anikroyale
I have never seen a S20 FE 5G automatically restarting. I recommend taking a backup of your device immediately in case it fails completely. And get it checked at a service center as soon as possible.
Also, did you install any app or software update recently?
vichu_zz
Software update did it (june update)
Anikroyale
When did you install the update? Like the exact date?
Athuljoy
Bro remove SD card
AK8800
I remember having same issue with A71 devices. coz of board issue . After doing all the troubleshooting, still having the problem, then contact service center.
Have you installed any new app recently?
Or try using your phone in safe mode. For a while
user963
Turn off auto restart
