Resolved! Solved
Regarding battery drain in S23 ultra
(Topic created on: 04-15-2023 07:43 PM)
Jaisonmathewkurian
Beginner Level 4
Dear family,
Is there anyone having any issues with the s23 ultra battery, I checked with safe mode and idle for 12 hrs battery got drained by 8% and was 92% available.is it normal or do I have any issues with my mobile battery? It's almost 3 months since I am using this phone.
Oliver2000
Please follow these steps:
• Adaptive Battery,
• Delete unnecessary apps and avoid filling up your storage above 80%.
• Optimise device in device care.
• Analyse the apps that consume more battery and then sleep or deep sleep those apps.
• Avoid using the phone in extreme temperatures.
• Update the device to the lastest firmware.
• Don't use the device while charging,
• Switch off unnecessary features I.e. switch off Bluetooth, location, prevent using majority of the time the device brightness above 75%.
• Restart,
• Send a error report if the issue persists.
• Finally, I recommend visiting a Samsung service centre.
If this thread was helpful and mark it as a solution. By clicking on three dots. Thank you for reading.
4 Comments
AsmedAli
I have the same issue with my s22 ultra even after spending 4500 dirhams on such a worst Mobile handset
Oliver2000
• Adaptive Battery,
• Restart,
Samsung_specialist
Hello,
Please follow the steps on the below link in order to help you solve this issue:
https://www.samsung.com/ae/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
