Resolved! Solved
Recent Page problem
(Topic created on: 04-28-2025 11:51 AM)
Jomy5472
Can someone give a solution to this? When I open recent pages on my device, it appears like this.
I dont know wht happend this.
Galaxy S23 fe
3 Solutions
VikrantTambade
Have you updated the device recently?
VikrantTambade
You try wiping cache partition by booting device into recovery mode. It should solve your problem.
If it doesn't, you may have to contact Samsung CS team.
VikrantTambade
Hopefully, it should be fine now. However, I will suggest you to check for other battery optimization checks.
11 Comments
VikrantTambade
Jomy5472
Bro, since December I've faced this same issue. Every month I do a security update on my device. Then I contact Samsung customer service, but the response isn't good. They only tell me to use phone safe mode. I tried safe mode, but nothing changed. Once I power off my device, after 5 minutes there's no problem. Five minutes after powering it back on, the same issue comes back.
Plz give me a solution
VikrantTambade
Jomy5472
How do I wipe the cache partition by booting the device into recovery mode? Can you please explain? Is there any data loss?
Jomy5472
Thanks, bro. I did that. Okay now. But I don't know if the same problem will occur again.
If the same problem coming i will contact u
VikrantTambade
Sure 👍
VikrantTambade
Jomy5472
Thanks bro
VikrantTambade
Pleasure is mine 👍
