Ram usage and battery drain in 4g network
(Topic created on: 08-15-2019 07:23 AM)
hariharasudhan
Hi samsung team,
I have few apple user friends who mock over battery drain in my s10 plus.
Is there major difference between apple's ram management and android's.
Kindly make the network mode to switch to 4g only when mobile data is turned on which would save lot battery..
Expecting best performance in battery with 4100mah battery
3 Comments
You have to optimize your phone and put unused apps into sleep, you can do that by going to device care > battery, and check which apps drains you battery most.
I did all the above, I have problem only during 4g network usage
I am talking about 4g power usage
