ROOTED PHONE Help
(Topic created on: 03-25-2024 08:08 PM)
g_ramanii
Hi, everyone
Today I've purchased a second hand S20 Fe 5G phone ,during my set up I found out that my phone is rooted and I got the error which I am attaching below. So anybody can help me out in returning back to the original samsung software.
And secondly is there any risk if i'm using any UPI apps on this rooted device.
16 Comments
Darkvader12
Expert Level 3
Oh this will cost you who rooted your phone ??
g_ramanii
What's the solution. CAN THE SERVICE CENTER GUYS CAN HELP
Arman-IND
Bro this is not software issue its a hardware thing the service centre will gonna tell you to change the whole motherboard becuase Knox is tripped therefore all the security apps like samsung pass , Pay and secure folder is locked permanently due to security reasons.
Its better to return this phone and take your money back
Darkvader12
Expert Level 3
Yes
Hampi
I would suggest you to return the phone to the owner if you can and get back your money. This phone will give you a lot of problems in the future.
g_ramanii
Bro it's not possible now
vivek1989
Bro who told u to purchase refurbished phone bro?
Its dangerous to buy refurbished phones
vivek1989
Bro this phone will give u headache
Return the phone .
Sayan_SS_
There is No Sollution.Try To Return Back The Phone To Onwer Otherwise The Phone Will Be A Great Problem For You Because Many Apps And Function Will Not Work And Will Also Lag.
