Quality issue with photo
(Topic created on: 01-11-2025 09:38 PM)
Jinnnnnn
When im taking photos the clarity of photo is very bad compared to that of iphones. Can't zoom even 1 time . So bad quality
2 Comments
foxonlyy
Hi brother, I will answer your question if you are a but protector camera Cheap kind. The problem is possible here, and if you don't install this thing, be sure to clean the lenses. "If your question is answered, click on ""Three points above"" and click on ""Solution has been accepted"" and thank you for your question, please, if you have an inquiry, I am here to help you."
Samsung_specialist
Please refer to the following guide to troubleshoot the issue.
Note: Before you try the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
Step 1. Go to Settings > Software update.
Step 2. Tap on Download and install.
Step 3. Follow the on-screen instructions.
Resetting the Camera app may fix the problem. Please follow the steps below.
Open Camera and select Settings.
Select Reset settings.
Tap Reset to reset the Camera app.
Force restart your device
If your device is still slow or freezes even after you reset the Camera app, try force restarting your device to resolve the issue.
Turn off your device by holding down the Volume down key and Side key, then selecting Power off.
Once the screen goes black, press and hold the Volume down key and Side key.
When the Samsung logo appears on screen, release both fingers from the keys.
