Problems s10+
(Topic created on: 11-26-2019 11:05 PM)
AmmarBaig
I have galaxy s10+ and i m facing hell of issues like the first one is proximity sensor and it is behaving very awkwardly like sometimes the screen goes off or on while using the earpiece or speaker. Another one is the light sensor same issue not working properly. The third one is lift to wake some times it works but most of the time not.The camera software is very grainy as compare to other third party apps. I dont know if these are hardware or software related issues please samsung look into these major issues imediately otherwise most of the samsung users will shift on other good brands.This expensive galaxy series is my major disappointment.
6 Comments
kkc001
if android 10 beta is installed then it is usual but if pie then wait for updates.
AmmarBaig
I am on pie
AmmarBaig
If others are facing same issues please report here.
AhsanA
Hi, Thank you for your interest in Samsung Pakistan. Please visit Samsung's nearest service center to get your issue resolved.
DrShahid
Yes Bro go near samsung center
suhaibgalaxyA10
samsung Galaxy s10 keliye July security update rolling out hochuka hai good news
