Problems in oneui 4.0
(Topic created on: 01-18-2022 01:45 AM)
satvik
So I have samsung s20fe5g and got One UI 4.0 update recently, so downloaded it and after all of this I am facing problem like tgere are many jitters and lags in screen that even though the screen is on high refresh rate, it is lagging in normal day to day task, this has not happened in One UI 3.0 but after this update, ut is disaster. Does anyone also face this issue?
10 Comments
Ak5hay_09
i am facing a big issue... after 24 hrs of one ui 4.0 i can not install any pps from playstore or galaxy store. i can not even update existing applications. tried of factory reset also.. no use. we actually need one more update yo get things fixed
satvik
Ohh, I didn't facw any of those playstore issues, but yeah in general device feels choppy and feels like some mid range budget 20,000 rs. Phone that lacks too much.
Ak5hay_09
yes... i don't knw what to do now actually
Ak5hay_09
sending multiple error reports not getting any fix
satvik
It willby the next update or will optimise most of it.
Ak5hay_09
do you know when samsung releases updates ? quarterly or yearly ?
satvik
Samsung releases security updates monthly for their S lineup so most probably in next month security update they'll club the optimisation coding too
Ak5hay_09
oh okay so probably hoping fixes... yeah i remember every 25th of a month i receive updates .. i think the actual date of ui 4.0 is 22nd of jan.. may be i m expecting jan security patch update on 22nd jan
satvik
Yes
