Highlighted
Lee369
I don't understand after spending such a huge amount of money why is the company not facilitating us with some solutions with regards to the problems faced with the usage of S10 series. I am facing battery drain issue, heat issue, lag in high performance games such as PUBG, fingerprint sensor not working always. This is not bearable as I have spent a lot and I want to enjoy my smartphone without much issues raised. I request proper updates and settling up of the issues prevailing in the Indian variant of Galaxy S10 plus to the company. If someone can help me with the maintenance and settling up of the issues in the handset then, kindly extend a hand.
23 Comments
Highlighted
simpleton
Same here. Feels like a downgrade coming from OP5. Back are the days of carrying and plugging the phone to the power bank while travelling.
Highlighted
Lee369
what's the benefit of buying such a high end smartphone when xiaomi gives better deals
Highlighted
gakshat14
I would really suggest you to then buy a Xiaomi, and when you see the difference let us know.
Highlighted
gakshat14
PUBG if running on high configuration always takes 2 twice the battery
Highlighted
Lee369
that's what
Highlighted
Lee369
how do we send our message to company regarding the improvements?
Highlighted
immi1
tag them ...twitter and here ....you will be get a answer very soon from Samsung
Highlighted
Lee369
what is the tag name?
Highlighted
Lee369
only samsung?
