Problem with my phone
(Topic created on: 03-24-2026 02:56 PM)
samsungmembers22
Hey is there a way to update my phone I have an s22 ultra and I am still on android 14 one ui 6.0 for context my phone is not brand new I bought it used
3 Comments
Since the Galaxy S22 Ultra is definitely eligible for One UI 6.1 and Android 15 (One UI 7) (depending on the current rollout phase), there are a few technical reasons why a used device might not be seeing the update:
​1. Regional Locks or Original Carrier (CSC)
​Even if the phone is unlocked now, its CSC (Country Specific Code) stays tied to its original region or carrier.
​If the phone was originally from a different country (e.g., a US carrier model being used in the UAE), it will only look for updates from that specific carrier's servers. ​If that carrier hasn't released the update or requires a local SIM to "handshake" with the server, your phone won't see it. ​2. "Cross-Flashed" or Modified Firmware
​Since the phone was bought used, the previous owner might have manually installed firmware that doesn't match the hardware's original intent, or they may have rooted the device.
​If the Knox counter is tripped or the system detects "Custom" software status, official Over-the-Air (OTA) updates are permanently blocked. ​3. Stuck Update Services
​Sometimes the internal "Software Update" app simply stops communicating correctly with Samsung’s servers. This can happen if the cache is corrupted or if a previous update didn't "finalize" correctly.
​Steps You Can Take to Force the Update ​Samsung Smart Switch (PC/Mac): This is the most reliable method. Install Smart Switch on a computer, connect your S22 Ultra via USB, and it will check for updates directly from Samsung's database, often bypassing carrier delays. ​Manual Check without SIM: Try removing the SIM card, restarting the phone, connecting to a stable Wi-Fi, and checking for the update again. ​Check Software Info: Go to Settings > About Phone > Software Information and look at the "Service provider software version." If you see codes like XAA/XAA/ATT, it confirms the phone is looking for updates from a specific US carrier (like AT&T).
samsungmembers22
Thanks for your time I will try and update on what happens with my phone
Samsung_specialist
Thank you for contacting us.
We understand your concern regarding not receiving the latest software update on your Galaxy S22 Ultra.
Kindly note that your device is eligible for newer updates; however, since the device was purchased used, the update availability may be affected by factors such as the original region of the device, carrier-specific software, or any previous software modifications.
To help resolve the issue, please try the following steps:
  1. Go to Settings
  2. Tap on Software update
  3. Select Download and install
  4. Ensure the device is connected to a stable Wi-Fi network and has sufficient battery
  5. Additionally, you may try updating the device using Samsung Smart Switch via a computer, which can sometimes detect updates not available over-the-air.
If the issue persists, the device may require inspection to verify the software status and ensure there are no restrictions preventing updates.
You may visit the nearest Samsung service center using the link below:
https://www.samsung.com/ae/support/service-center/
For further assistance, you may also visit:
https://www.samsung.com/ae/support/contact/
We appreciate your understanding.
