tommynick
11-17-2022 04:04 AM (Last edited 11-17-2022 04:15 AM ) in
Galaxy SI've recently " after one UI 5.0 update " noticed that whenever i try to listen to media in general from any app the sound cuts off then back on ... then realized that the volume level is constantly changing while am listening to media , so i thought maybe the volume buttons are stuck but have them few presss and they where fine , restarted the phone and it was back to normal and then 5 hours later the same problem is back
2 Comments
Samsung_special ist
11-17-2022 09:52 AM in
Galaxy SHi,
Kindly contact us, so we will be able to help you more and provide you with a service center you can go to.
Follow this link: https://www.samsung.com/ae/support/contact/
VikrantTambade
11-17-2022 10:53 AM in
Hi,
You can try wiping cache partition by booting device into recovery mode and check.
