Problem with Oneplus buds
(Topic created on: 02-29-2024 12:01 PM)
HemantChauhan
I have one plus buds is working fine before few months. I am updated both one plus buds and mobile s23 ultra. Facing problem in sound in all videos which are in whatsapp or in any OTT plateform. I am also went to one plus service center but not found any solution. I think after few updates in mobile this problem is occurred. Please help,
Thanks in advance
2 Comments
iamrohitkm
You should always use the same brand, man both. Better use galaxy buds 2 pro no such issues occur.
cs_member8
Dear Samsung Member,
As per your query, we request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
