Problem synching system clock with Weather clock (widget)
(Topic created on: 01-23-2022 06:14 PM)
Samsung_XlbwG6A
Beginner Level 4
Hello,
I have S10e. After a system update two days ago, I noticed that the system clock and the Weather clock are not synching. Please the screenshot where you can see the system clock on the top left corner showing a different time (5:47)from that of the Weather clock (12:06) in the middle of Home Screen between two apps: Parking & Daman.
I'd be thankful if you could tell me how to fix this problem.
Thank you.
Najib
7 Comments
VikrantTambade
Hi,
System clock is showing your current time whereas the weather al widget shows the time of last refresh. Check Your widget's refresh time interval.
Samsung_XlbwG6A
Beginner Level 4
Hi Vikrant,
Thank you for your reply. I tried all options of Auto refresh:
Never
Every hour
Every 3 hours
Every 6 hours
Every 12 hours
Every 12 hours
Nothing worked so far. I can't uninstall this widget as well.
Thank you for your time.
VikrantTambade
Hi,
You can remove this widget and add it again.
Go to home settings and check whether lock home screen layout is enabled. If it is enabled then disable it and remove the widget and add it again.
Samsung_XlbwG6A
Beginner Level 4
Hi,
Unfortunately, it didn't work. But thank so much for your help.
Regards,
Samsung_specialist
Thanks for sharing your advice on this!
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link it will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
mZoOnY
Turn on auto sync along with GPS
Keep wifi connected. Now restart
