Problem occur in S24 series
(Topic created on: 03-04-2024 01:18 PM)
syedhamid1
I buy new samsung S24 ultra from online store "samsung.ae" but when i call some one or some one call me he didn't hear my voice this not one two time every day same problem occur who facing this probem.
I go to samsung service center he said wait for software updatation but when software is come i update my mobile the problem is same not fixed it,
Can any body tell me how to return this mobile to samsung
4 Comments
Buhamod
I have the same issue with the mic!! Samsung should do something about it 😡
laibah_59
I don't think there would be any updation to turn this mobile to Samsung. Any way you could ask the owner maybe He can solve the problem
laibah_59
Or the samsung manager
Samsung_specialist
Before you try the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. You can update your device's software with the following steps:
1. Go to Settings > Software update.
2. Tap on Download and install.
3. Follow the on-screen instructions.
Also, ensure that nothing is covering the microphone or speaker on your phone. A poorly placed screen protector or case is one of the most common causes of sound distortions during calls.
Additional troubleshooting steps include:
1. Maximize the in-call volume.
2. Restart your device.
3. Start your device in Safe mode.
4. Turn off Wi-Fi Calling.
5. Check if “Mute all sounds” is off.
6. Ensure that your SIM card is in good shape.
7. Perform a Factory data reset on your device.
