Problem in slo mo
(Topic created on: 01-19-2025 11:32 PM)
Laughingcoffin
I don't use slo mo that much but when I started to take a video I noticed this issue on my s22 plus.
It never happened before, can someone explain what's happening in here?
7 Comments
arulsreekumar
During slo-mo recording you need a good lighting to avoid this.
If there is no enough light especially for slo-mo and super slow-mo video quality will be a problem and kind of flickering will be there.
Samsung_OneUi
In Low light slow mo will always struggle because of higher frame rate. You nees enough light like in sunlight afternoon time for slow motion.
cs_member10
Dear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Go to Settings>Display>Adjust the brightness.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
goodthings
Please clear catche and clear data of this app also reset camera settings and reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
rushi912
Bro you are shootings this in LED LIGHTS for sure so that light is flickering in slo-mo
Actually LED LIGHTS ARE FLICKERING IN NATURE but our eyes doesn't encounter that easily so we getting continuous light from LED.
BUT IN slomo configuration the frame rate is more than the frequency of LED so that flickering of LED light is easily caught in SLO-MO
So for best slo-mo shoots the the natural light is preferred...!!!
Even under the bright sun the problem still persists.
It's only happening in slow mo and super slow mo.
