Problem in Repair Apps Function in Recovery Menu on updating ONEUI 6.0
(Topic created on: 02-11-2024 05:03 PM)
rdview
i am using s22ultra.. in One UI 5.1, the repair app function worked well. but after installing One UI 6.0 the repair apps function not working.
Device ignores request to repair Apps and fails to check, repair, and reoptimize all apps as it should be doing and simply restarts the device normally.
Please let me know ,is this genuine issue or am i only facing the problem?
3 Comments
First of all plz bro tell me where i can find repair apps option i think its a pretty well feature that i dont know about
BharathKBs
That's found in Recovery menu
rdview
yep..its pretty well feature...(but it is not responding as the name suggest)
it is under recovery mode
