Problem and irritating about something
(Topic created on: 05-03-2025 06:12 PM)
Govind_
Samsung always prefer notification and forget about quick setting tab.
I mean, Swipe down to see notification is good but it should be in different order.
Feedback - notification should be left side and quick setting option should be in right side or vice versa.
Let's suppose, i need to open notification, then i will swipe down on the screen but it should be either on right or left side as currently it is.
And if i need to open quick setting Optio, i will swipe down from left or right side, which is currently work if we swipe down from top corner of left or right side, which is really bad and feel like we are using Something big in our hand.
So, samsung should focus on it.
5 Comments
I agree. Left or right swipe should work on entire screen. I don't need 2 steps to open quick settings tab and swiping from top right corner isn't convenient. Due to this issue I merged both pages for now
Govind_
Things are not working for me. As other brand, some popular brand using that method that i want to say. Left side scroll notification and right side scroll quick setting panel. This is so simple. Why do we need to swipe from edges of the top of the corner ? We are using almost tab, 7 inch display. So Samsung should understand this.
I agree.
cs_member8
Dear Samsung member,
▪ In the One UI 7, The Quick Panel and Notification Panel are now separated (as default setting). We made this change to improve usability.
▪ Previously, you had to swipe twice to access the quick panel. This new design makes it more convenient.
▪ Please try using the new user interface. It's designed for easier navigation.
· Swipe down from the top right corner of the screen to open the quick settings panel.
· Swipe down from anywhere else at the top of the screen to open the notification panel.
▪ But, if you feel uncomfortable, you can set like before (One UI 6)
* Path: Quick panel > Edit > tap ‘Panel settings’ on the top left > select Together
Govind_
Why we need to swipe from top ? As we swipe from anywhere, notification panel open. So same thing should be for quick setting panel.
My concern is - left side swipe (not swipe from top corner) for notification or right swipe(not top corner swipe) for quick seting panel. That's it. Samsung have 7 inch display so we face problem when using phone. We need easy thing, not difficult
