Problem Of Restarting In My S20Fe.
(Topic created on: 07-19-2021 10:46 PM)
Sameehrex
Do Anybody Have Experienced Problem Like Your Phone Getting Restarted After Working On Any Apps Or Camera.I Am Experiencing It Since The Release Of New Security Update.If Anyone Have Any Suggestion Or Solution.Kindly Write To Me.
13 Comments
AMPK
Expert Level 3
Yes it is happening to all
Sameehrex
Due There Is Any Solution For It?
알렌WithGalaxy
Yes it happens on devices with exynos 9611
Sameehrex
What's The Solution To Solve This?
알렌WithGalaxy
Software update is the solution wait for it
Swetabh_Singh
S20 Fe have Exynos 990.. and no its not happening to everyone...
알렌WithGalaxy
Yes ,not happening for snapdragon devices
But there is problem of restarting with exynos
Swetabh_Singh
I too have S20FE and i am not facing any such kind of issue.. can you please elaborate how to produce it so that i can check...
Anyhow the basic workaround is to clear device cache... did you tried that?
Sameehrex
It Probably Happens When Using Camera.Everything Was Perfectly Alright Until The New Security Update.
