Potrait Mode for All Galaxy (Galaxy S6/S6 edge/S7/S7 edge/S8/S8+/Note8/Note5)
(Topic created on: 01-17-2018 04:56 PM)
theKeshavKr
Expert Level 3
Got Potrait Mode on Galaxy S7 and its works as smooth and charm as Google Pixel 2 with the help of Google Camera.
If you wish to get the same comment on this post, i will give download link for apk and respective settings to use. Also works on both front and rear camera. Currently only works on human faces.
UPDATED SETTINGS AND LINK :-
Preferred Settings for Galaxy S7 and S7 edge:-
IN B-S-G SETTINGS
Model:Pixel XL
Config camera HDR+:Nexus 6 Hdr+ Auto
HDR+ parameters: Default (lowest)
Potrait Mode on all models: On
IN DEVELOPER SETTINGS
Enable (on) these and rest should be off:
camera.faceboxes
camcorder.fastswitch
camera:gcam_enabled
cameraprogress_overlay
camera.enable_vesper
camera.gouda.front
camera.raisr
NOTE: REST SHOULD BE DISABLED
APK DOWNLOAD LINK:-
https://drive.google.com/file/d/1pnRl3qTo64duFXAVJFJJOm_G3TwDnSxA/view?usp=drivesdk (Old Version)
If getting pinkish colour on potraits then change Manual fixed black level offset to 0.00 (Exynos S7)
LATEST UPDATE :-
New version got realeased which fixes the purple or pinkish tint. Download link. https://drive.google.com/file/d/1pPWR2MjeSeC-b_9B5TI1Oi_RfOti6IXo/view (New Version)
Note: Currently works with S7 and S7 edge but can try on other handsets too such as S6 and Note 5.
Sample pictures :-ae516864-67c1-4ff0-817f-86c35e5b4e44.jpg
18 Comments
Abhisheek
Dil behlane ke liye tik hai.. U r just impressing ur self.. Keep it up
theKeshavKr
Expert Level 3
what do you mean to say..
Abhisheek
I mean it is good.. But not comparable wid current flagship like iPhone X.. Note8.. S8.. Pixel 2
theKeshavKr
Expert Level 3
but everyone cannot afford note 8 and iphone x and s8 currently doesn't have it officially. it is good for everyone that getting same features without paying heavy amount
Mubark
j7 pro me support he
theKeshavKr
Expert Level 3
try kar ke dekho
admin_
Thanks for being with Samsung and sharing this information. We would like to inform you that officially Portrait mode is not available in the requested Samsung device. Samsung never recommend to use third party application in the device as it may cause issue.
Be sure to hit ♡ when you find an answer that works for you.
s01gautam
https://play.google.com/store/apps/details?id=com.application.onead&hl=en Your friend has invited you to try OneAD app. OneAD is Refer and Earn + Shop and Save mobile app. Install this free app become a member and earn up to 2.5 Lakh Rs per month. Your referral code for registration is reffer code -"M1EQFP"
Sam141
hey man how can i check if i recieved any updates on this app?
