Pink line display problem
(Topic created on: 11-05-2024 02:25 PM)
Rjsnyk
Beginner Level 3
Samsung S23 plus pink line display........
No one time replacement given to this flagship phone
7 Comments
Rvira
ruchita_
My s22plus also has Pink line problem
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for replace/repair it's. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
● Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off. Kindly power buttons on the device after by pressing power for 5-7 seconds.
● Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Rjsnyk
Beginner Level 3
I hav performed all the steps provided and also hav visited service center......they told to replace the screen which is the option.....sad part is being a flagship phone ther is no one time replacement for this models wer as there is free replacement for S21 series........ so please request you to provide fix or add this model in the website.....its sad even being proud owner and owning hifger model we dont get the service which others get...
Balmikeekuma
Beginner Level 4
Samsung galaxy a73 pink line and green line software update issu and the service is not working
