RaviNaidoo
a month ago in
I recently did the security patch upgrade on my S25 ultra however noticed that the phone gets very hot even on use for short durations and it struggles to connect via Android Auto. Anyone else experienced the same or similar and how did you resolve it
8 Comments
Munatsi399
a month ago in
https://www.samsung.com/africa_en/support/?cid=sea-alert-redir
Contact support for assistance between 8am to 8 pm
The-Kid-Deė
a month ago in
Are you using Samsung Original cable??
RaviNaidoo
a month ago in
Yes
The-Kid-Deė
a month ago in
Let's just wait for another update and see
Efgie
a month ago in
Sometimes it happens when you have high power consuming apps or games, on settings try to set to deep sleep when you not using these apps. Also make sure these apps are updated to latest versions.
Efgie
a month ago in
Also you can go to Settings - Device Care - Dignostics. This will do a dignostic check and tests.
RaviNaidoo
a month ago in
Did that as well and all tests came back clear
Efgie
a month ago in
Mostly they come as normal and indicate where issues are found
