MMZK
3 weeks ago in
I have a s21 fe
I have been trying to connect it to my laptop via usb cable
I have tried different cables(original one also), usb ports and other laptops as well
The default configuration is at transfering files
But still its not showing in the windows explorer, however the laptop does makes the connection sound while connecting
Any solutions?
Qaisar308
3 weeks ago in
Install Samsung Driver for Windows
Or
use smart switch.
Or
use smart switch.
MMZK
3 weeks ago in
Drover already installed
Qaisar308
3 weeks ago in
There could be a reason.....
Did you encrypt your phone? By connecting with one of your PC
I had done this in the past, and my phone connects to my PC only, not any other one.
Now i forgot how i encrypted that.....
But I'm not sure about your phone, buddy
aakashnawab7
3 weeks ago in
It seems like your mobile has faulty USB port. Data pins are not working.
USB port replacement is the only solution.
MMZK
3 weeks ago in
But otg usb drive is working with mobile
aakashnawab7
3 weeks ago in
If OTG is working fine, then port is okay
aakashnawab7
3 weeks ago in
When you connect device to laptop/PC.
A pop up apers and you need to give permission to access Device storage. Are you getting that pop-up ?
MMZK
3 weeks ago in
No
MMZK
3 weeks ago in
Mobile pe popup ni araha likn notification mei file transfer option show ho raha hai
