Sam010
Beginner Level 4
03-15-2023 10:21 AM (Last edited 03-15-2023 10:21 AM ) in
S23 ultra
3 Comments
Samsung_special ist
03-15-2023 10:57 AM in
Galaxy SHello,
For assistance, please visit one of our authorized Service Centres to check it for you. You may refer to the link it will guide you to the nearest service centre to your location https://www.samsung.com/ae/support/service-center/
TMan296
03-15-2023 12:58 PM in
Is it because the phone was in the Sun cause you were driving or soemthing like that? It was my issue before.
But you can try reducing background usage of apps you are not using the most.
mZoOnY
03-16-2023 06:41 AM in
Definitely a background app issues
You can try
1. Ultra power saving
2.GO TO deep sleeping apps and select all by hitting the + button
3. Go to device care and see if there are some recommendations
4. Enter safe mode ( not recommended .only to make sure)
5. Back up everything using smart switch on pc and do a full reset
Good luck 👍
You can try
Good luck 👍
