Overheating and battery draining.
(Topic created on: 04-16-2022 08:29 PM)
Makonnen
I just bought my Samsung Galaxy S8+ and it heats so badly and drains quickly even when not using it while connected to the charger. How can this problem be solved?
12 Comments
MgBean
Check for any background apps that might be draining your battery 🔋 or try to see any issues from device care panel
Makonnen
Umm.. the device care panel hasn't replied to my first concern a few months ago, how do I access quick response?
MgBean
This is the device care panelScreenshot_20220416-193207_Device care_41107_1650130328.jpg
Makonnen
Alright, thank youn
DontPanic_42
Optimized or not, that doesn't sound right.
Makonnen
I guess so too
ManDeepest
Is it brand new or second hand?
Makonnen
It's brand new
ManDeepest
It seems like the battery issues are caused by the lack of software support if can remember your phone was released in 2017 running Android 7 and it only got software support for 2 years that's back in 2019, its still a good phone but the battery it's letting it down.
