Over Heating and Battery Drain for Samsung S21 Ultra
(Topic created on: 06-03-2022 06:55 AM)
Prasanthyeso
Over heating an battery  drain using zoom calling from Samsung S21 Ultra after installing new updates
2 Comments
Hi,
Is it specifically due to zoom app? Did you check ur battery usage? Which app is consuming more battery?
If any specific app is consuming more battery then clear it's app cache memory.
Samsung_specialist
For assistance, please visit one of our authorized Service Centres to check it for you. You may refer to the link it will guide you to the nearest service centre to your location https://www.samsung.com/ae/support/service-center/
