12-01-2023 01:05 PM in
Galaxy S- Mark as New
12-01-2023 01:06 PM in
12-01-2023 01:08 PM in
Galaxy SHope they fix it in December update
12-01-2023 01:09 PM in
12-01-2023 01:10 PM in
Galaxy SDo you any idea when the December update will be available
12-01-2023 01:19 PM in
12-05-2023 11:50 AM in
Galaxy SThank you for bringing to our attention the battery issue you've encountered following the recent software update. Here are some steps you can take to troubleshoot:
1-Use the Original Charger:
Ensure you are using the original charger that came with your device. Using non-original chargers may affect battery performance.
2-Optimize the Device:
Go to Settings.
Navigate to Battery and Device Care.
Select Optimize Now to enhance your device's performance.
3-Close Background Apps:
Make sure to close all unnecessary background apps to conserve battery life.
4-Try Safe Mode:
Restart your device.
When the Samsung logo displays, press and hold the volume down key until the lock screen appears.
On the lock screen, "Safe mode" will be shown in the lower-left corner.
Testing in Safe Mode helps determine if a third-party app is causing the battery drain.
5- Restart Your Device:
Simply shut down your device and restart it. This can resolve temporary issues affecting battery performance.
We hope these steps help improve your device's battery life. If the issue persists, kindly visit the service center directly.
12-11-2023 09:44 AM in
