Resolved! Solved
Notifications panel problem
(Topic created on: 06-02-2025 10:42 PM)
rajdeepsinh2248
When I open the full notifications panel, I can't easily collapse it without touching it three times; it's too irritating. Please fix the update so that opening and collapsing the full notifications panel requires only one touch.
जब मैं पूरा नोटिफ़िकेशन पैनल खोलता हूँ, तो मैं इसे तीन बार छुए बिना आसानी से बंद नहीं कर सकता; यह बहुत परेशान करने वाला है। कृपया अपडेट को ठीक करें ताकि पूरा नोटिफ़िकेशन पैनल खोलने और बंद करने के लिए सिर्फ़ एक बार टच करना पड़े।
cs_member10
Dear Samsung Member,
We appreciate you taking the time to share your suggestions and appreciate the time and effort you have spent sharing your valuable feedback. We are continuously working to make our products better and more efficient.
2 Comments
cs_member10
Thanks for giving this update in ui 8
