Resolved! Solved
Notification help
(Topic created on: 03-29-2024 12:28 AM)
Shadaab87
The notification on the settings icon. I cannot for the life of me find what that notification in the settings menu is for. There should be a shortcut in the long press menu to take you directly to the notification.
Shadaab87
I just want to say sorry and thank you.. Just found the solution 2 mins after posting the issue. Samsung is freaking amazing!!!!!!1711658011438.jpg
Shadaab87
