Highlighted
hi everyone! m not getting much of a difference between music and voice mode on dolby atmos on galaxy s9 both on earphone and speakers....is it normal.
8 Comments
Highlighted
something happened in August update before that you can feel real difference
Highlighted
I don't think both s9 and s9+have dolbyatmos only s9+ have dolbyatmos effect🤔
Highlighted
S9 also has atmos...official
Highlighted
https://youtu.be/aSuj0FXUgHI
Highlighted
Thank you for reaching out to the Samsung community! We would like to inform you to follow the steps below to resolve your concern:-
- Go to settings > Accessibility > Hearing > Mute all Sounds > Enable it > Disable it.
- Go to Settings > Sound and Vibration > Sound quality and Effects > Dolby Atmos > Disable it and then Enable it.
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Highlighted
did everything as instructed.....still the same
Highlighted
someone who has s9 or s9 plus please comment.....thanks
Highlighted
any S9 user....please comment
