Not able to activate Call forwarding
(Topic created on: 03-31-2025 04:46 PM)
vivek221
I am trying to active call forwarding in my S24 but it shows failed to read data
4 Comments
Kaustav_Ray
Expert Level 3
If your Samsung Galaxy S24 is showing "Failed to read data" when trying to activate call forwarding, here are some steps to fix it:
Possible Causes & Fixes:
Check Network Connection:
Ensure you have a stable mobile network connection. Try enabling and disabling Airplane Mode to refresh the network.
Use Dial Codes Manually:
Instead of using the settings menu, try using these dial codes:
Enable Call Forwarding (All Calls) → Dial **21*PhoneNumber# and press Call. Disable Call Forwarding → Dial ##21# and press Call.
Check SIM Card & Carrier Support:
Some carriers may not support call forwarding. Try a different SIM card to check if the issue persists.
Restart Your Phone:
A simple reboot can resolve temporary network or software glitches.
Reset Network Settings:
Go to Settings > General management > Reset > Reset network settings. This will reset mobile, Wi-Fi, and Bluetooth settings but won't delete personal data.
Contact Your Carrier:
If nothing works, your carrier might need to activate call forwarding on their end.
Kaustav_Ray
Expert Level 3
If this helps, please accept it as a solution. Click the three dots on my reply and select 'Accept Solution.' Thanks!
Follow me more information.
cs_member10
Dear Samsung Member,
Please use the below mentioned link to perform these easy troubleshooting steps to resolve this issue:
https://www.samsung.com/in/support/mobile-devices/how-to-enable-disable-the-call-forwarding-feature-...
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
Samsung Customer Support"
Akash375
Disable the auto blocker, select LTE for SIM preferences, then restart your phone. Try again.
