Noise in phone body
(Topic created on: 04-07-2019 03:07 PM)
SMK1
I am using S9 Plus. I have not dropped it by any mean but some noise (liquid or metal) is coming whenever I shake the phone a little also. This is happening since yesterday.
I have checked all the buttons and sim tray for any loose contact, but they are intact and solid.
Please help/suggest.
7 Comments
Not applicable
its from camera
SMK1
is it normal? it never use to come...or i never noticed before
Goyal0011
yeah
Not applicable
im using A7 2018 when i keep my device down its start to rattle so when i open camera its wont
sonijiS20p
did u use your mobile in the water before this condition?
ivin200
noise should be from camera....
open camera app ..and shake...
now listen for noise if camera app is opened??
munidilli
there is no problem in your phone that's because ois. when you're turn on the camera it's
gone
