Network speed indicator
(Topic created on: 08-03-2021 01:22 AM)
Subham21
Is there any way to get the network speed indicated in the status bar through settings/Goodlock?
7 Comments
No,there is no official way to indicate internet speed on the status bar.
Subham21
Sad.
If satisfied with my response then click at 3 dots near my above comment and accept it as solution to help others 👍
MrDragone
You can use speed meter by 3rd party app to getting information about network speed.
If that's your solution then click comments 3 dots and accept solution to help others.
Subham21
It's not because I asked if it could be done through settings/Goodlock.
MrDragone
No bro.. No such feature not available in samsung till now. Let's see in one ui 4.0 should be there.
animeshmodi
Bro currently, it is not possible.
You can download 3rd party app from play store,
https://play.google.com/store/apps/details?id=com.internet.speed.meter.lite
To get it in future updates, provide feedback to samsung to include it in future major os updates.
