01-02-2025 08:19 PM in
Galaxy SSolved! Go to Solution.
01-02-2025 08:58 PM (Last edited 01-02-2025 09:00 PM ) in
Galaxy S1. *Check Display Settings*: Go to *Settings* > *Display* > *Screen mode*. Look for any options related to color filters or screen tint.
2. *Edge Panels*: Go to *Settings* > *Display* > *Edge panels*. Check if any color filters are enabled.
3. *Accessibility Settings*: Go to *Settings* > *Accessibility* > *Visibility enhancements*. Check if any color inversion or filter settings are enabled.
Additional Steps
1. *Restart Your Device*: Sometimes, a simple reboot can resolve the issue.
2. *Check App Settings*: Although you mentioned that the filter doesn't show up in screenshots, it's still worth checking the app's settings to see if there are any options related to color filters.
3. *Reset App Preferences*: Go to *Settings* > *Apps* > *All apps* > *Menu* (three dots) > *Reset app preferences*. This will reset all app preferences to their default
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-02-2025 08:28 PM in
Galaxy S- Mark as New
01-02-2025 08:29 PM in
01-02-2025 09:52 PM in
01-02-2025 08:41 PM in
01-02-2025 08:44 PM in
Additional Steps
01-02-2025 09:21 PM in
01-02-2025 09:23 PM (Last edited 01-02-2025 09:23 PM ) in
01-02-2025 09:07 PM in
