Highlighted
Hi guys
=>Im getting S20+ plus (Exynos) at 50,000 in flipkart sale.
=>I researched a lot about it and just found 2 issues:
1. Heating
2.Battery Drain,less screen on time around 3-4 hours.
=>So should i buy it or go for oneplus 8 pro
=>Im not a heavy gamer just normal day to day tasks
1.Does the temperature go beyond 45'c ?
Is Exynos 990 good for normal usage and is battery life good like 5-6 hrs ?
How about oneplus 7t pro bcoz so far it did not have any screen issues.
S10 lite(Fhd) flat-40000rs
7t pro (Qhd) curved -40000rs
My budget is till 50,000 only and these are my only choices
1.S20+.    getting at 50k
2.OP8 pro   55k
3.OP 7t pro  40k
4.S10 lite     40k
I'm not a heavy gamer i just need phone for normal day to day usage like watching movies, camera and op7t pro got Snapdragon 855 plus so no performance issue and who cares for wireless charging or ip rating 😂 xd
its just if i put 15k more i get s20 plus or op8 pro and that's why I'm in a lot of confusion.
14 Comments
Highlighted
Also Note10+ is for 55k
I prefer you can go for Galaxy Note 10+
Highlighted
I dint like note 10 design xd
Im stuck between these 4 phones
1.S20+. Battery issues like drain and heat
2.Oneplus 8 pro. Display black bar issue
3.Oneplus 7t pro. No issues like above 2
4.S10 lite. No issues but no qhd resolution like above
Highlighted
s10 lite or s20 fe pick one.
leave the Qhd+ as it's not practical on daily usage.
it eats ur battery.
Highlighted
But Note10+ has no issue
Highlighted
go with one plus
Highlighted
You also take S20 FE as it's effective price will be 39999 after taking all discounts, offers.
If you don't care about gaming, performance I feel at 40k price that will be best bet.
It is newer than S20+ so may be they have improved on issues with Exynos 990 compared to S20 series.
Personally I do not feel right to spend more than 30k for Chinese phones, if your budget is high then go with Samsung or Apple.
I was in your situation, I would have bought S20 FE.
It has almost all features of S20 including IP68 , Wireless charging.
Highlighted
S20 plus is also good but i checked all reviews and found only 1 problem i.e battery drain
Idk maybe they have fixed it in update
For op8 pro it has display issue which is not great
Oneplus 7t pro has QHD at 90HZ no display issue or battery problem just has curved edges and im getting it fot 40k
S20 + also impressed me a lot 😂
Man buying new phone is **bleep** hard
Highlighted
one plus camera **bleep** as compared to s20 plus.
Highlighted
If you are convinced about S20+ then go ahead.
There are 3 issues with it COMPARED to other phones , even S10 , Note 10 series.
It heats up in normal usage, network reception is not great, performance is not good in gaming, heavy tasks.
OnePlus 7T Pro is one year old and as I said I personally won't spend more than 30k on Chinese phone , whether its OnePlus or Redmi.
If you know OnePlus is overhyped brand. It is at best inferior OPPO hardware + better software. All part of BBK group which owns Oppo, Vivo, Realme, OnePlus, iQOO.
If you like S20+ then also I will suggest you to buy S20 FE and save money.
Also don't spend too much time to analyse and asking others their opinions.
Decide yourself what are your must haves, then go ahead.
