My s25 ultra not detecting sandisk flash drive
(Topic created on: 09-27-2025 12:27 AM)
nihal026
What could be the problem , it was working fine in flip 4
5 Comments
drpl
Format it and try
shs
Try to disable auto blocker
nihal026
Did that, but no luck
Samsung_specialist
Inspect the ports on the phone or tablet.
Restart the phone or tablet.
Reconnect the USB flash drive and check the connection.
Format the USB flash drive.
Make sure your USB is set for file transfer.
Move your files.
From Security and privacy> More security settings turn off (Block USB connections while locked)
Also you can try enabling devolper option
Default USB configuration
nihal026
Formatted with both file systems and still not working. While it working perfectly in laptop. Also tried all other steps you mentioned but no luck
