3 weeks ago (Last edited 3 weeks ago ) in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
2 weeks ago in
Galaxy SDear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
