Massive battery drain on Samsung Note 10 plus Exynos (media storage)
(Topic created on: 04-08-2021 10:15 PM)
EdoardoD
Screenshot_20210408-173555_Battery Tracker.jpgScreenshot_20210408-160530_Settings.jpgScreenshot_20210408-161023_Device care.jpgScreenshot_20210408-161103_Permission controller.jpgScreenshot_20210408-161111_Settings.jpgLast update makes me crazy. Last month was a nightmare, charging phone 3 times a day because Media Storage drain all the battery. I contacted 3 times samsung support and nothing has changed.
Can someone help?
7 Comments
Not applicable
You can try reset. Or wait for next update, N10+ is listed to get updates monthly.
EdoardoD
I did try both, reset once and updated 2 days ago, nothing has changed
AKSM215F
Check if SD card having any issues or mount & unmount it & reboot
EdoardoD
I don't have any SD card unfortunately
AKSM215F
Then wipe cache partition
EdoardoD
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
