09-17-2023 05:33 PM in
Galaxy S- Mark as New
09-17-2023 05:37 PM (Last edited 09-17-2023 05:37 PM ) in
09-17-2023 05:40 PM in
09-17-2023 06:27 PM (Last edited 09-17-2023 06:30 PM ) in
Galaxy S.
1. Can install internet speed meter who want to monitor their net speed.
2. Ik Secure Folder is not AppLock ... But it can be used as AppLock... And it's more secure than AppLock ig
3. "Never" ... Why would someone need it ? 🤔
4. With RegiStar maybe you can activate Tap back twice to take screenshot. You can use One hand+ to take screenshot too ... Yeah simple gesture to take Screenshot is missing 😕
5. Bah 😒 ... "Chapri" feature
6. Samsung phone is not for gaming...
7. Animations are good enough ig
8. Hmmmmm...
9. Security 🔥
10. You can make your own themes according to your need. Most of MiUi themes don't look good.
11. Na ... Most of the people don't do customisation... So keeping things simple, it's a separate app
12. Really ... Is it that important ??? 😐
13. There are infinite possibilities in OneUi after new update of LockStar and ClockFace
14. Like what ?
15. Hmmmmm...
16. Hmmmmm...
17. It's good enough ig ...
18. Bro ... If you have used OneUi from past, then you must appreciate OneUi5.1 is the best in terms of smoothness and animations...
19. There is a default launcher... And in MiUi you cannot change the default launcher and use full screen gesture at the same time 😬
20. Sometimes it goes more than 50GB if you use all features regularly... Generally it's 20-30GB.
21. You can change it if you want.
22. Hmmmmm...
23. It can do that. It's already there.
24. Depends...
25. There is.
09-17-2023 06:41 PM in
09-17-2023 06:58 PM in
09-17-2023 07:24 PM in
09-17-2023 06:45 PM (Last edited 09-17-2023 06:46 PM ) in
Galaxy S(2) When I put Auto clicker on this the mobile phone gets lock to many times.
(3) Same as point one if some body is watching video on youtube and preparing something or doing some creative work which will take more time than 10 min , and there hands become some how dirty then it's very irritating to unlock phone 2-3 times with it!
(4) Yes it will save too much battery but they should provide when the persons requirement is there he can put it on/off
09-17-2023 07:01 PM in
