Low in call volume s21 fe
(Topic created on: 08-25-2023 09:14 PM)
kooldude7285
After last update the volume from earpiece has become half. Same is the case with Bluetooth earphones. Earlier i could hear everything clearly on 65% volume now even on 100% i have to be in quiet room.
Anyone facing this issue? Any solution?
4 Comments
kooldude7285
Yes
Anki201
Did you get August security patch update on s21 fe
kooldude7285
Nope i guess not yet released for exynos
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We would request you to register your concern in Samsung Members Application as you are facing an issue after the update. So, our concern team gets back to you as soon as possible.
Please report the problems you are facing in your Samsung smartphone with a fresh log file which is in the form of a pdf file/jpg format. And also share a short video clip or 4 to 5 photos along with a pdf file, before and after the issue occurred, for better understanding.
Please share the device log file within 15 minutes of the issue occurrence by using the error report option via the Samsung Member application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
