Lodging S24 ultra problem instagram whatsapp snap
(Topic created on: 09-28-2024 01:30 AM)
foxonlyy
Delayed video playback is not as fast as iPhone. Can you solve this problem?
Whatsapp + instagram +snap chat + youtube
Every time get Loding screen
We need to fix this problem. She hates using the phone in social media programs.
2 Comments
Samsung_specialist
If you're experiencing issues with apps crashing or not working properly , and noticing that your phone is slower, here are some steps you can take to troubleshoot and potentially resolve these problems:
- Restart Your Phone: A simple restart can sometimes resolve performance and app issues.
- Update Your Apps:
Go to the Google Play Store and check for updates for apps that are causing issues.
- Update Your Phone’s Software:
Go to Settings > Software Update > Download and Install to ensure your phone’s software is up to date.
- Clear App Cache and Data:
Go to Settings > Apps > select app > Storage.
Tap Clear Cache and Clear Data. Note that clearing data will remove app settings and login information, so you'll need to log in again.
- Ensure you have sufficient free storage on your device. Go to Settings > Device Care > Storage to check and manage storage usage.
- Uninstall the apps that are causing issues, restart your phone, and then reinstall them from the Google Play Store.
