DrSatyam
09-17-2023 09:57 AM in
7 Comments
phoenix_14
09-17-2023 10:01 AM in
Reajdust lockscreen in Goodlock
Not applicable
09-17-2023 10:06 AM in
If you are using the GoodLock application, there is a plug-in called LockStar,, By using LockStar you can fix this easily. Simply manage layouts one after one. Things will be settled. Don't cross over or overlap any layout over there, If you don't prefer overlapped layouts. Please accept as a solution if that helps you. 🙂
Delhi_se_hu_BC
09-17-2023 10:25 AM in
But now widgets not working and lockstar also crashes afrer few hours.
Not applicable
09-17-2023 12:50 PM in
There will be some issues with the updates,, Simply clear the cache, or if you don't modify or change things too much then clear the data, And set things.
DrSatyam
09-17-2023 10:35 AM in
Thanks
Not applicable
09-17-2023 12:52 PM in
"Accept as the Solution" request is still pending from your side.
PrajwalKasture
09-17-2023 04:05 PM in
Aapke airtel sim me data alerts aate hai kya 😐
