alwaysdjdas
Facing VoLTE problem with Jio sim on my S20 FE 5G from last June security patch update. My 1st sim card slot is airtel and 2nd sim card slot is jio. While I am using internet through airtel, both sim's VoLTE working fine. But, when I switched internet from airtel to Jio, then Jio's VoLTE automatically disappeared and can't make and take calls without VoLTE on jio. And, when again switch data network from jio to airtel then Jio's VoLTE automatically appeared. This problem is coming after June security patch update. Anybody found this issue?? BTW, I checked my Jio sim on other handset to test the issue, but on the other handset VoLTE works perfectly.
17 Comments
Saajan_yk
Not facing problem..tried what u said and getting volte in all such scenario
alwaysdjdas
Then, why my device showing this issue continuously from last update 😣😣
Saajan_yk
Report this issue...go to get help -》 error report.
Maybe in next update it will be fixed.
alwaysdjdas
Will try
abhithecool
Getting your jio sim changed may help.
alwaysdjdas
But, my Jio sim working perfectly on another handset.
Chaman17
Changing the sim slots might help, i.e. put jio sim in slot 1 and airtel in slot 2.
Also, go to settings - > connections-> sim card manager - > more sim card settings - > enable smart dual sim.
See if this works.
alwaysdjdas
I tried with two airtel sim. Now volte working fine on both airtel sim. Only Jio sim facing this issue
Chaman17
Hmm, okay. Pls explain: When you're switching internet from airtel to jio, you're saying that volte disappears. So, that means you're not able to access internet too, right?
