02-05-2023 10:15 PM in
Galaxy S- Mark as New
02-05-2023 10:17 PM in
02-05-2023 10:20 PM in
Galaxy S5g showed in my friend's mobile when I put my sim, after I put my sim back to my mobile 5g is not showing.
02-05-2023 10:23 PM in
07-31-2023 10:52 PM in
Galaxy Snot working in my s20 5g
02-05-2023 10:25 PM (Last edited 02-05-2023 10:47 PM ) in
Galaxy SI am considering that your phone is updated to latest security patch released recently
02-05-2023 10:33 PM (Last edited 02-05-2023 10:51 PM ) in
02-06-2023 12:42 AM in
02-06-2023 12:50 AM (Last edited 02-06-2023 12:51 AM ) in
Galaxy SYou need odin 3.13 tool (go to samfw website to download) to run in the PC
Download the android 13 version (6 to 7 GB) of the S20 FE 5G variant from the samfw or sammobile website
Extract only the CP and home CSC file and import it in the corresponding slots in the PC odin software
Connect a USB to type C cable directly to your PC
Backup your data using samsung cloud in your phone
Switch off the phone and wait till it turns off completely
Press the volume up an volume down simultaneously for 5 seconds and insert the type C cable (in between that time) to enter the download mode
Then click start in the odin to start flashing the CP and the home CSC files
When the phone conpletes restarting, remove the cable
Now 5G will work in android 12.
(Do not flash wrong files or do wrongly. It will brick your phone)
02-06-2023 08:36 AM in
Galaxy SI'm using Android 13
